PM2.5 Monitor (MH10-PM2.5)
Site web MCO Home : http://www.mcohome.com
Détecteur de CO2 / Z-Wave / MCO Home
Inclusion/Exclusion: Activate Inclusion/Exclusion mode in the gateway. When device powered on, long press S1 & S3 synchronically to enter interface for inclusion or exclusion of Z-Wave network.
* If device has not been included into any Z-Wave network before, "- - -" will display on the screen.
* Then press S1 once, "- - -" flashing and device enters into learning mode to get a node ID. If inclusion is success, a node ID will display on the screen. If not, "- - -" will stop flashing in 20
sec.
* If a node ID displays, it means the device is already in a Z-Wave network. To press S1 once can remove it from the network. "- - -" displays and press S2 once can return to normal work.
Batterie(s): Alimentation 12V
Données remontées en Z-Wave : PPM, Température, Humidité
20160620102846.pdf
