Detector de CO2 / Z-Wave / MCO Home
CO2 Monitor (MH9-CO2)
Inclusión/Exclusión: Activate Inclusion/Exclusion mode in the gateway. When device is powered on, long press K2 can enter interface for inclusion or exclusion of Z-Wave network. * If device has not been included into any Z-Wave network before, "- - -" will display on the screen. * Then press K2 once, "- - -" flashing and device enters into learning mode to get a node ID. If inclusion is success, a node ID will display on the screen. If not, "- - -" will stop flashing in 20 sec. * If a node ID displays, it means the device is already in a Z-Wave network. To press K2 once can remove it from the network. "- - -" displays and press K1 once can return to normal work.
Grupo por defecto del controlador: NOLF,2
Batería(s): Alimentation 12V ou USB
Datos disponibles en Z-Wave: CO2, Temperatura, Humedad
| 20160531160808.pdf
