Sitio web : http://www.mcohome.com
TIPO
| PERIFERICO
| PARÁMETROS EEDOMUS
| NOTA
| DOCUMENTACIÓN
Detector de CO2 / Z-Wave / MCO Home
PM2.5 Monitor (MH10-PM2.5)
Inclusión/Exclusión: Activate Inclusion/Exclusion mode in the gateway. When device powered on, long press S1 & S3 synchronically to enter interface for inclusion or exclusion of Z-Wave network. * If device has not been included into any Z-Wave network before, - - - will display on the screen. * Then press S1 once, - - - flashing and device enters into learning mode to get a node ID. If inclusion is success, a node ID will display on the screen. If not, - - - will stop flashing in 20 sec. * If a node ID displays, it means the device is already in a Z-Wave network. To press S1 once can remove it from the network. - - - displays and press S2 once can return to normal work.
Grupo por defecto del controlador: 2
Batería(s): Alimentation 12V
Datos disponibles en Z-Wave: PPM, Temperatura, Humedad
| 20160620102846.pdf
