RemSwiid (SW-ZRC1)
Sitio web Swiidlifx : http://www.swiid.com
TIPO | PERIFERICO | PARÁMETROS EEDOMUS | NOTA | DOCUMENTACIÓN |
Mando a distancia / Z-Wave / Swiidlifx |
Inclusión/Exclusión: Press and hold both the "Up" and "Down" command keys of the remote until the blue Z-Wave LED lights up (after 2-3 seconds) and stays lit indicating the remote is in the Setup Mode. Press once on the "All" key and the both the green and red LEDs will also light up to indicate that the inclusion process can begin. The 3 LEDs will then blink rapidly and turn off to indicate that the process has completed successfully. If not successful, the LEDs will remain lit solid until they time out after 30 seconds. |
| ZRC1 Users manual v1.08.pdf ZRC1-AS.pdf |
