Ring Keypad
TIPO PERIFERICO PARÁMETROS
NOTA DOCUMENTACIÓN
Controle el acceso / Z-Wave / Ring
Ring Keypad
Inclusión/Exclusión: Classic Inclusion Steps:
1. Initiate add keypad flow in the Ring Alarm mobile application – Follow the guided add flow instructions provided in the application
2. Select add manually and enter the 5 digit DSK pin found on the package of the keypad or the QR code found on the back of the keypad
3. Plugin the keypad to line power
4. Press and hold “1” key for three seconds
5. When the inclusion process is complete, the LED on the keypad will be solid blue, then go out.
6. Test the Keypad. Any button presses would beep
Grupo por defecto del controlador: 1
Non supporté, intégration en cours...
Ring_Keypad_EU_Z-wave_Manual.pdf
